Stereo to mono summing
Hi - firstly thanks for the advice on usb - serial adapters, I'm now the proud owner of a moxa ethernet - serial adapter and sleeping well at night...
I need to take a stereo signal in on two inputs and output it as a stereo on two outputs but also as mono on a single output - what is the best way of doing this with the lowest overheads in a soundweb 9088?
I guess I can use a 2:1 mixer but if I just take the left and right stereo outputs from say a gain module and connect the 'wires' together at the input of an eq, will i get unwanted effects (phasing etc)?
Chris.
Chris.
No need to worry about phasing because it's impossible to do. Combining two signals into one signal requires a processing object. No exceptions.
Dan
Chris.
