Logic Issue
I am having a hell of a time programming my first Blu80 I have a logic circuit to turn the system on and off at set times but the client would like to have a button on the Blu10 that overrides the timed off and allows them to turn the system off manually with another button. If anyone has any ideas I sure could use the help.
Bob
Bob
I'll take a stab and throw a couple of pointers your way. You don't give us much to go on and I'm assuming that when you say 'turn the system off' you mean mute it!
You could mute/unmute a master mute object in an n input gain device that you put in line with the signal paths immediately prior to all your outputs.
The master mute could be changed by either by the calendar preset recall arrangement or you could also make it directly controllable by dragging it onto a button on your Blu10.
Hope that helps and let us know what you did to figure it out!
Steve
