From the London Architect help file: Serial Trigger/Table
The Serial Trigger/Table is used to send custom serial strings out of the RS-232 port on the rear of the Soundweb London device. It can be set up in two modes:
* List mode which allows two serial strings per input - one for a LOW (0) input and one for a HIGH (1) input.
* Table mode which treats the inputs as binary thus giving a greater number of states.
The lights on the logic object design block indicate the current selected preset. These are operational in simulation and when online to the device.
Serial String Edit Table
Clicking on the edit button next Serial Table in the Properties window will open the following window. ~image not copied to the user group~
Enter the serial string in decimal, hexadecimal or ASCII.
Properties
* Number of Inputs - This sets the number of inputs, selectable from 1 to 12.
* Mode of Operation - This sets the mode of operation to either List or Table mode.
* Serial Table - Click here to set up the serial strings.
Dan
Properties
Dan
