HiQnet and Studiomanager
kainosmedia
Hi all,
Would it be possible to run London Architect controlling a BLU-16 and at the same time run Yamaha studiomanager to control for example a LS9 from the same computer. I know it's not recommended (or even possible) to use Cobranet networks together with other Ethernet networks, but what about HiQnet?. Is it asking for trouble? Should I get two computers?
/Anders
/Anders
/A
You could put either the London or the Yamaha on a wireless network and control one wirelessly and the other one hard wired. That would get both on your computer via two seperate networks.
You could also look into a PCMCIA/USB to Ethernet/Wireless adaptor as the second network card. It would be a lot cheaper then investing in another computer.
Also, it's completely possible to use CobraNet on the same network with other protocols and other software. Pretty much the only time CobraNet becomes an issue is when you have cheap hardware.
Dan
