Relay switch box controlled by 3088
kainosmedia
Hi all,
I am planning a five zone installation where I intend to use the 3088. In one of the rooms there are two different positions for the stage so we need two speaker systems.
When the stage is in the first position speaker A is left and speaker B is right. In the second position speaker A is right and speaker C is left and delay speakers D and E are used.
Also, in the first position I intend to use one subwoofer placed somewhere near speaker A. For second stage position I'll maybe add another subwoofer placed close to speaker C.
The two positions will be chosen from a wall panel controller 9015.
Is there a relay switching box with, say 6 balanced inputs and 12 outputs that can be controlled from the logic control output of the 3088 available on the market? Or should I pull out the soldering iron and put one together myself? That shouldn't be too hard, should it?
I apologise for the somewhat blurry description of the installation and I hope it makes sense in some way.
Thank you for your help,
Anders Haggblom
Kainos Media
Finland
Anders Haggblom
Kainos Media
Finland
3088 Output 1: Speaker A
3088 Output 2: Speaker B
3088 Output 3: Speaker C
3088 Output 4: Delay D
3088 Output 5: Delay E
3088 Output 6: Sub near A
3088 Output 7: Sub near C
Put a source selector before each output and create a parameter preset containing all of the source selectors.
Preset for \"First Position\"
Source Selector 1 = Left
Source Selector 2 = Right
Source Selector 3 = no signal
Source Selector 4 = no signal
Source Selector 5 = no signal
Source Selector 6 = Sub
Source Selector 7 = no signal
Preset for \"Second Position\"
Source Selector 1 = Right
Source Selector 2 = no signal
Source Selector 3 = Left
Source Selector 4 = Delay Right
Source Selector 5 = Delay Left
Source Selector 6 = no signal
Source Selector 7 = Sub
Dan
