Fan noise
SteVEN
Hi,
This is hypothetical so bear with me.
If I wanted to use a 9088 in a domestic critical listening/home theatre application where the only location for the unit would be in the listening space is there a quieter fan available?
Is the not insignificant noise generated from the turbulence of the air flow through the grille cutout?
Has anyone tried swapping fans at all?
Steve
Steve
So did you have any success in finding a suitable part? Would you be kind enough to share a part number?
Steve
hope this is of some help.
Mark
No google hits on that one but I know Sunon are a fan manufacturer. I'll have a dig around on their site.
Thanks for your help!
Steve
I'm looking at using a 9088 for my HT so the fan noise issue is of importance to me.
How did you go with locating a quiet fan? Did you get one that suited your purpose?
Andrew
I suppose the 9088 could be located remotely in an equipment cupboard or rack and balancd lines used to send audio with the benfit of noise rejection. That of course assumes your receiving equipment has balanced inputs. Otherwise you'll need to install input isolation transformers.
