push button volume control
Ok, so I've got this 17 inch touch screen and my customer wants to use it as the control panel for a multi blu-80 install. There seems to be some issues with sliding your finger to move a fader. At times it is difficult to grab the trolley and if your finger \"skips\" on the screen, it will disconnect from the trolley.
Thus the solution seems to be assigning many buttons to the fader and having each button's on state be a different value. This works great except, if you switch off a button, then no value is assigned to the fader and it will goto -inf. What is even worse, if I assign a button to a value of -inf and I turn it off hte fader goes to +10.
I tried to radio button link the buttons, but I am unable to.
I really didn't want to make a whole bunch of presets as it is not an elegant solution. Another kludge would be to use a router and have many different fixed gain controls, but again not elegant.
Any ideas.
Any ideas.
Dan
Graham
Dan
