PIP USP3/CN bundle addressing
I'm new at this...How do I set the USP3/CN to pull down the cobra net bundle I've assigned as the output in a BLU-80?
I have the bundle set as a multicast bundle since it is going to at least five CTs amplifiers to drive the main cluster. The bundle is number 1.
So in the control panel for the USP3 cobra net input, there is the RxA, RxB, RxC and RxD and the channel input drop down lists.
A little direction on this would be great. I don't have the hardware yet, this is just a design.
Scott
  • ChrisChris Posts: 37
    RxA, RxB, RxC and RxD corresponds to the four input Bundles in the USP3CN module. Compare to the four Bundles in the BLU80.
    In your case set for example RxA to 1, leave the others at 0.
    Channel 1 & 2 Input corresponds to the two channels of DSP in the USP3CN module, i.e. the two amplifier channels.
    Here you select which Bundle (A, B, C or D) and Slot (1 - 8) to take the feed from.
    In your case set Channel 1 to A1 and Channel 2 to A2 (If you are using slot 1 & 2 in Bundle 1)
    Chris
  • scott180scott180 Posts: 80
    That's kinda what I thought. What throws me is that the output names on the USP3 don't update to the input names like the audio paths. The outputs of the PIP card still say \"No Signal\". But I assume everything is fine.
    Scott
