Crestron Mixer Module
In the Crestron mixer module that is on this web site, there is a help file that goes with the module that defines all the parameters that can be controlled by the module. I see lots of references to the inputs to the mixer but no reference to the ouptut of the mixer. Specifically, the output fader. This is the only fader I want to control. How do I do that ?
Paul J Daoust
SAVI
  • You are correct that the Mixer Module does not control outputs...neither does the automixer or n-gain modules. There are two ways to get around this problem. The easiest to use the Mixer 8-Chan BASIC module that has been included in this download. This module does give access to master volumes and mutes. The N-Gain 8-Chan BASIC gives access to the Master controls in an N-Gain object.
    Or you can use Generic module and use the DI Protocol guide to look up the master control's SV's.
