Home BSS User Forum BSS Archive Threads Discussion Soundweb Original
9015 with 9088iis
I would like to know if there is a way to use a 9015 controller to individually adjust several different gain faders with the selector switch choosing between the faders. I need to be able to adjust 3 input gain stages and 5 output faders independently and using configurations/presets is problematic since the gain settings on the idle faders revert to their original values when changing configurations.
I remember that there was a post long ago concerning the use of a resistor ladder switch and single pot to accomplish this type of control but I cannot find this post (if indeed it did exist).
All help will be greatly appreciated.
Mark
    This can't be done with the 9015 and a 9088.
    It can be done with a 9015 and a BLU-xx Soundweb London device using logic processing and serial strings.
    Dan
  • Thanks for the confirmation, Dan. I will move the controllers up to 9010s.
    Depending on how many controllers you're talking about, it'll probably be cheaper to use BLU-16 or BLU-160 devices and 9015 controllers.
    Dan
