Nice not
A design wich worked fine on the last version gives a over 100% in the new version Thanxs a lot
  • timotimo Posts: 10
    The design file i used in version 14r3 ran about 99% of the processor . In the 2.00 version it will not compile . The only way to get it working is to take out 8 inp. delay's . The thing is that the imput delay's are handy when i have to make a sub array with canceling in the back .
    If i have to recalculate 8 delay lines with for instance 2,94ms on top of the delay i use to make a arc subline out of it it will take more time wich i normally do not have in a festival situation .
    I do not use logic
    I just down graded to 14.3 and everything is working fine again . The design is allready sent to 2 people from bss . I'll wait for a response
    This was caused by an error in the way the compiler handled delay compensation. It's been fixed in v2.02.
    If your design file is still over 100% in v2.02, then it actually should have been over 100% all along and was only under 100% because delay compensation wasn't executed fully. So, now it's \"right\". If you don't care about \"right\", just turn off delay compensation and it will shrink back down.
    Dan
