Source Selector with Bundles + Ducker bypass does not work
Hey guys...
Can i put the source selector like that on a design?
Changing the bundle source?
And for some reason, the ducker doesnt work. Even if i bypass the ducker i still can hear the sound, the funny thing is, when the ducker is with the bypass on, the ducker will mix the BGM and the mic together. when i turn of the bypass, it will duck.
The ducker has a setting in its properties that allows the mic to be sent to the output.
In its default state, the ducker will mute the program input and not allow the mic source to pass. modify its properties and the mic signal will be sent to the output.
cheers
Rob
Dan
I just to know why the ducker with the bypass on will combine the 2 sources together.
Dan: I wish a have smoked the home-rolled.... But, I didn't put the print screen of the ducker here. I will put it tonight.
On the pic you cant see well the line. But everything is connect.
So the problem is, when the Bypass is off the 2 signal will merge together.
Does it means that with the bypass the ducker will act like a summer?
Anyway, the ducker is doing exactly what it's being told to do. The bypass button turns on/off the ducking function. When the ducking function is off, the mix function is still on because there is no bypass for it. I think most people would prefer that it work your way, but it doesn't for now.
Your problem is fairly easily solved by putting a gain object on the mic signal before the ducker. Link the mute button on the gain object to the bypass button on the ducker and the mic signal will be muted whenever you bypass the ducker.
Dan
Thanks alot Dan
