Error while saving .architect file
Hi,
I've got this error shown in a pop-up window while saving my . architect file:
0x80040154 Source : (null)
Description : (null)
Error Interfaccia non registrata.
File .\\RoadrunnerFile.cpp, Line 1749
If I click \"OK\", the saving procedure seems to go on properly, since I can re-open the file. But again if I save it, I've got the same error shown.
Any suggestion?
Any suggestion?
Check out your App Preferences in both apps to make sure that HiQnet adapter sharing is switched on.....
I forget what each app calls this option exactly, but it's something like 'share this PC with other HiQnet apps'....
Best of Luck!
I tried to share the network connection in L.A. and S.A., but that doesn't correct the problem.
It seems to me it's a file issue: if I modify other .architect files, I can save them without any problem.
I've got that pop-up error only with this particular file.
This file contains 3 BLU-160s, 11 BLU-120s, 5 BLU-8s and one BLU-10.
I found that if I delete one of the three 160, the pop-up doesn't appear anymore and I can save the file.
But since I've got lots of links between objects here and there and I did lots of programming, I would like not to delete an entire device and start again...
I hope there's another solution, I don't know, an \"integrity\" checker for the .architect file...
Anyhow, even if with that pop-up window, the file seems to be saved and I can go on line with it. Only I'd like to understand why that pop-up appears.
Bye.
