Home BSS User Forum BSS Archive Threads Discussion Soundweb Original
A boatload of 9010's up in smoke!!
So, the Atlas 24 volt power supply that gave 8 9010's life let go of a regulator and started putting out 40 volts. Needless to say, the 9010's are now paper weights. Is there anything I can check inside before I send them off for repair?
  • Inside? No. Outside, you could check the head of the person who decided to put eight 9010s all on the same power supply.
    Dan
  • CrashCrash Posts: 12
    Ah yes, there are a lot of \"oddities\" in this building. Thanks for the reply Dan, I ended up sending some of these off to Mike at Creation In Nashville.
