Motorized fader controller for Soundweb
Chris
I know this has been discussed and fantasized about before, but I wonder if there is anybody who has found a working soloution?
The idea is to have a programmable faderboard to control a Soundweb system via RS232 or Ethernet. There would be maybe 8 motorized faders to control gains, possibly 2 or 3 layers to the fader bank, 8-16 buttons to control mutes and presets, etc.
Some companies offer similar products to work with DAWs. But those all depend upon protocols which we don't have in Soundweb.
/Chris
/Chris
They initiated IP control between the two boxes and had a custom script written that allowed the DSP to process the return information about fader position, button status, etc. Not sure you can do that with London.
I'm not a code guy so it may be possible, but it doesn't seem like the logic section can take an IP command and understand it to the point of generating a SV based on an external IP command and value string. You would almost need a third party control system to handle that.
All you would need is one of the small Crestron processors to crunch the numbers on the same IP network as the JL Cooper and the London hardware.
Check out the new RMC3 processor. Very compact and not too expensive.
