Event logs
someone wanna make sense of this? the xxxxxxx is not the real name
6348 Going offline 0 30/03/2009 12:50:07
n 6347 Going online 0 30/03/2009 12:48:50
n 6346 Going offline 0 30/03/2009 12:48:31
n 6345 Keep alive failed \"xxxxxxxxxxxxx\" 31/03/2009 00:38:08 Node 0x3030
n 6344 Keep alive failed \"xxxxxxxxxxxxx\" 31/03/2009 00:38:08 Node 0x3030
n 6343 Keep alive failed \"xxxxxxxxxxxxx\" 31/03/2009 00:38:08 Node 0x3030
n 6342 Keep alive failed \"xxxxxxxxxxxxxx\" 31/03/2009 00:38:08 Node 0x3030
n 6341 Keep alive failed \"xxxxxxxxxxxxx\" 31/03/2009 00:38:08 Node 0x3030
n 6340 Going online 0 30/03/2009 11:07:40
n 6339 Going offline 0 29/03/2009 14:50:52
n 6338 Keep alive failed \"xxx\" 29/10/2000 16:30:57 Node 0x3030
n 6337 Keep alive failed \"xxxxxxx\" 13/02/2000 19:51:23 Node 0x3030
n 6336 Keep alive failed \"xxxxxxxxxxx\" 12/03/2009 22:02:54 Node 0x3030
n 6335 Keep alive failed \"xxx\" 29/10/2000 16:34:10 Node 0x3030
You should call tech support and email the file.
Dan
Speaking to BSS, their comments are below....
On startup, all boxes send out Discovery messages, to announce their presence to the network. They do this for 5 seconds.
· The boxes who need to communicate constantly (eg: boxes with links, logic) continue to send out Keep Alives between each other.
Those that don’t need to communicate constantly, stop sending out Keep Alives after the time out period.
· It is normal to see “Keep Alive Failed” when boxes are being rebooted since most boxes will stop sending the Discovery messages after 5 seconds.
· Once all boxes have started and the initial timeout has elapsed you would not expect to see ‘Keep Alive Failed’ messages unless there was a network problem or a box is rebooted.
Cheers
Rob
