9088LL output \"Y\"
any practical experience creating a hard-wire \"Y\" from a line output? Need to do this cause of complex setup; need to send output to 2 different inputs on other gear.
Should be fine....?
Should be fine....?
If the inputs to your 2 devices have typical input impedances of 10kohms or more, then you should be fine connecting via a y split. This arrangement will only lose a fraction of a dB in terms of voltage at the inputs.
