Home BSS User Forum BSS Archive Threads Discussion Soundweb Original
9088 + 9088 expander -
trying to cut down on the amount of cable im humping around, im thinking bout running 8 lines of audio over CAT5 using the 9088 + 9088 expander-
I realise its not actually CAT5 protocol, but does use CAT5E cable-
couple of questions:
1) I assume the 9088 8in 8out lives at the desk end, put audio through it outputting on network- CAT5 to the expander- and output from that into the amplifiers? im using the 9088 as a processor to run 8 way monitor mix or equivilant
2) is there any obviously problems with latency? with what i propose to do?
3) The cat5E cable- is it pin to pin or a crossover cable? I propose to run it for 50 meters.
4) Im assuming that all the processing is done on the master unit and the expander mearly facilitates the cat5 - audio conversion?
thanks in advance
Dan
    Soundweb latency is <3ms from any input to any output. It won't matter.
    Use cable wired to the T568B standard.
    The 9088 and the 9008 each have exactly the same DSP processing power.
    Dan
