9088 dead
dirk
I just got a ten years old 9088. I plugged it into main power but nothing is happening. No LED active at all, fan not running, no noise at all.
Looks like the unit is not getting any power but power cable is ok. Main fuse and the fuse on the board are ok either.
Any idea where to look for the problem? It really looks like a failure of the power supply to me.
Thanks for any help.
Dirk
Dirk
George.
thanks for your info - I will do would you suggested.
When looking at the board under full light I saw that R1696 and R197 seem to be burnt (beeing black in the middle).
I read them as 1 Ohm 1/w resistors 5% tolerance - right?
(brown - black - gold - gold)
Measuring shows infinite resistence.
Is that something which fits to a dead C60 or is it more likely that this indicates a different problem?
Thanks for your help!
Dirk
George.
thanks for the info - will check the components you mentioned and see how it goes.
Thanks again.
Dirk
