Minidrive 344 set-up
Safetyman
Hi,
I have set up my newly acquired 344 so that the outputs are configured as 1,2 bass and 3,4 top/mids with linked inputs for stereo operation and Linkwitz filter slope. However I need to set the crossover point, initially at 120 hz and also put in a 5 db cut at precisely 315 hz for the tops. I do have a downloaded copy of the manual, but cannot seem to find how to go about this.
Can anyone help with how to do this, please ?
cheers.
Ian
cheers.
Ian
Continue to push up or down on the four way rocker selector switch to reach the first adjustment for the first EQ filter. Use the rotary encoder to change the value. You can adjust filter type, frequency, cut/boost, and bandwidth.
Mark
Ian
