Blu8 controlling a Source Selector - problem
Ayone else having issues with Blu8s consistently not recalling the last available source?
I've tried with 6 position, 7 position and 8 position source selector objects. The Blu8 correctly scales the controls so that you don't see 7 and 8 with a 6 position source selector, for example, but when you try to select the last source (6 in this example) it won't take first time.
I tried turning allow none to off and using properties to disable the unused positions on the encoder but it's still intermittent.
This is with 2.06r3 and I've tried several different Blu8s and Blu800 and Blu160 frames.
Use proxy device was always turned on too.
FYI: proxy mode is meaningless unless the BLU-8 needs to control SVs on more than 9 different devices.
Dan
2) Place a BLU-80
3) Place a BLU-8
4) Place a source selector in the BLU-80
5) Set the source selector to 6 inputs
6) Drag&drop the source selector to the rotary selector on the BLU-8
7) Go online and load the design file
8) Use the BLU-8 to select source 6
9) Watch the source selector in London Architect change to input 6
10) Repeat all of the above steps using a 7 input selector
11) Repeat all of the above steps using a 5 input selector
12) Repeat all of the above steps using an 8 input selector
There are my steps to make it work perfectly every time without exception. Provide your steps which will make it malfunction and tech support will have something to work with.
Dan
Dan
If you rotate the BLU-8 knob TO the last position of the source selector and push the knob in, it selects the correct position. If you rotate the knob PAST the last position, the LED will remain white at the last position, but pushing the knob does nothing.
Dan
Is there a way for BSS to fix this in London Architect or should I just train the users to avoid going too far at the last position?
We basically did the same as you when I visited the BSS Dealer in Stockholm. At the venue we were using a design file that simply had source selectors dropped onto the Blu8 encoder as well.
Yes and yes.
Dan
So will that be a patch fix or do we have to wait for the next release of LA?
There's no way to know what changes will be released to the software or when they will happen until after all of the changes have been tested. If the fix for a non-fatal bug ends up causing more problems or just different problems, it'll be pulled from the release. That means there's really no definite way to know in advance what will be released or when (except for fixes of fatal problems). Anybody who tells you otherwise is just guessing or hoping.
Dan
