Issues with Getting Designer to Install
Guys,
I am trying to install designer on a different machine and it unpacks up to 99% and then disappears into oblivion and nothing happens!
Any ideas
It is the current version 1.50 from the Download page
I am stumped a little
Thanks in Advance
Dave
Any ideas
Thanks in Advance
Dave
Alternately, if you have another computer that already has Soundweb Designer installed, you can just copy the C:\\Program Files\\BSS Audio\\ folder from one computer to another. You will need to manually create a shortcut on your desktop and/or start menu, but the software will run just fine.
Dan
I don't normally have the patience to do this one by one to help find the culprit so I just shut everything else down in one hit and it usually works.
Martin
