Power on/off Blu-80 over RS232
Would it be possible to power up the Blu-80 over the RS232 or over a trigger signal ?
If so how do I do it ?
Obviously you can't power off any unit completly and expect it to respond to a control command!
So, option 1: program a \"stand-by mode\" as a parameter preset (like: mute all outputs) and trigger that with rs232 or whatever you fancy.
Option 2: use a mains power relay to turn on/off the Blu.
Which method to use is entierly up to you and what you think suites your application.
/Chris
