Home BSS User Forum BSS Archive Threads Discussion Soundweb Original
Channel Codes Unknown
I'm using Soundweb Original with the latest software. All my units are 9088iis. I've got all my DSPs back from repair and working. Some are in different locations in the rack so I could keep my house audio working during the repair time. I have a control panel with combo lists from which I can select house music sources. Before the units were moved and/or repaired, all the house music sources worked perfectly. Now I don't have house music going to all the DSPs however. The problem is I've moved some of the house music sources to new locations. On the DSPs where the house music isn't working I get the following error message at the bottom of the screen.
ID 1 Channel Codes: 'Music Source 1: unknown 'Music Source 2: unknown… on so on down the list. I know I need to create a new combo list that will allow me to put in the new locations for the sources but I can't remember how to do it. I hope I'm not being obscure in my question but I've worked on it for several hours and haven't made any progress. I've even scoured the help file and SW docs file but haven't found the information.
Thanks for any advice.
  • That's not an error. You just need to do a serial export to generate the codes. Call John Clark at HMG and he can walk you though how to do it. 1-800-931-2357
    Dan
