Sw3088 volume increment via serial
Hi.
I have a sw 3088 which i'm trying to control via rs232 using RAW_MSG.
I'm using Soundweb Designer 1.50 build 68. sw3088 with firmware 1.06.
I can control some stuff just fine, but having problems with the most basic function - volume levels.
I would like to have simple (even not so simple ones would do) commands for increasing/decreasing gain or mixer volumes (or anything else that does what i need to do).
I can set a fixed volume level just fine, but it's not really good for my setup. I want command like \"increase this volume by 5db when i press a button once\"
Morphing a fader to spin pair didnt help much as those buttons have the same handle and method as the fader, so it only jumps to a fixed value.
Is there some other method i could use for a fader handle?
Using those control in ports with a relay does work, so it must be possible via serial too, right?
Relays aren't the best option, but if i can't figure this out i'll have to go that route
SDK mentioned about a SW_AMX_SPIN msg, when i try this from SW Message Tool it still jumps to a fixed value instead of increasing.
Do i need something special in that 'number' field? My device cant talk AMX so it might become a problem with ACKs...
This thread said you cant link to spin buttons via logics, is that the case with serial too? (yea i know it was about different model)
http://www.bssaudio.com/phpBB2/viewtopic.php?t=292&highlight=spin
I read about naming the device \"mydev +s\" or \"mydev +f\" - i know what +s does and i'm using that now, but what is +f? Couldnt find any documentation about it.
ps.
the fan noise was a disappointment
Any help would be appreciated.
ps.
Obviously, this solution doesn't work if you need up&down control of more than 4 state variables because you run out of control ports.
Dan
admin edit: Dan always forgets that you have to assign the control outputs in INVERTED mode. If you use NORMAL mode, the controls just run themselves up or down to the full extent of the fader.
That sounds like a handy workaround.
But logic outputs output +5V and inputs expect just a trigger to close the circuit. I still need to use some sort of relays to make it happen.
I cant just wire them from output to input, i think that won't work.
Is there a way to configure logic outputs to just close a circuit.
Do you have some wiring tips? How have you wired them?
Dan
Vibration stops when i remove the wiring. And started again when reconnecting.
All i did was to connect out 1 to in 1 etc (connectors 1 through 4)
No other connections to logic ports.
Tried without linking output common to input common and with a link.
Made my controller to activate the button, wait for 0.1s and deactivate, control signals seemed ok in the control panel.
If i've understood correctly, an input port is activated by grounding it, hence common ground. By connecting it to an output port, i'm feeding it +5v, so maths doesn't really add up. (Although i do suck at maths..)
I guess i'll go buy a few solid state relays tomorrow and make a quick little circuit to handle it.
Sounds to me like you are closing both \"volume up\" and \"volume down\" buttons at the same time. You have to make sure only one of the up/down pair is triggerd.
Don't bother connecting anything to common, it's just a ground reference and all control inputs/logic outputs are already internally referenced to ground.
/Chris
In control ports section of designer, i had chosen \"normal\" instead of \"inverted\" for the trigger type. Explains everything.
With normal-mode it constantly grounds all ports thus activating all ports.
Thanks guys.
Now i got another problem, but it must be something silly too.
I use mute buttons of a dummy mixer as triggers for logic outs. Mute buttons were the only ones i could morph to leds and be able to connect to logic outs. (would some other buttons be better?)
When i press these buttons on the control panel with a mouse, it lights up, that workaround thing works and fader moves.
But when i activate the mute via serial, it lights up in the mixer window and control ports window, but it doesn't change the state of respective logic out.
I'm sure i had this working before, so must be some little thing. Gotta keep on looking.
Dan
I had just messed up some handles, no big deal.
Now everything works perfectly.
Thanks for all the help, that workaround is great.
