Moxa NPort with FDS-366
Trying to use London Architect to control an Omnidrive 366. No problem hooking up directly to the serial port. But then we tried a Moxa NPort 5110 to access via the network. Can't seem to get a connection. I don't think it's a soundweb issue. The virtual com port is not showing up in windows Device Manager. Anyone out there try this combination?
First, run the Configurator software which is listed on your start menu under NPort Management Suite.
Second, run the RealCOM Installer which is listed on your start menu under NPort Management Suite/COM Port Mapping.
The first one sets up the Moxa device so that your computer can talk to it. The second one assigns the virtual serial port to the device.
Dan
Though, I am still having issues. I installed the NPort management software, but it can't find the nport 5110 when I search. I can however find it using the nport administrator tool I got with the 5110. Any other tips for troubleshooting?
Thanks much!
Dan
