9015 issues
Howdy, new guy here.
I use tons of other software for pretty much all audio systems so I am pretty familiar with the basics to this stuff here.
I have a 9015 connected to an older 3088 that does not switch presets correctly. I searched all the groups so far and came up with maybe I just need to add more \"OFF\" presets to fill up each of the switches positions?
What happens is that I have 2 presets that I need to switch between. I have the presets set and wiring correct (also have a simple master volume slider that works perfectly). When I switch to the second position on the dial, it goes to preset 2, then quickly jumps back to preset 1 even thought the switch is in position 2. If I keep rotating the switch, it will do the same reversion until it reaches the 5th position, then it stays in the preset 2.
Suggestions?
Suggestions?
Create a preset for each position (even if they do not do anything in the software) then it will track correctly.
So for a 9012 you need 5 positions (presets or source selector), for a 9015 you need 8.
The control port measures the resistance of the selector (which is basically a resistor 'tree'. )
Enjoy
Rob
