Trouble adding to 5/6 in 336T Minidrive
My trouble is similar to KevinJames post of 8/09. But I have the 336T Minidrive processor. I've learned to abreviate the outputs. My setup was LLHH (full range), Xover set to BOTH.
Now I've added to the array, total 4 speakers per side, and need to use 5/6 in full range. The setup now is LLHHHH. Xover set to EDGE. Settings for 3/4 are same as 5/6. But the frequency response of 5/6 drops bad after around 3K. 3/4 are fine, set to full range. There are no EQ settings except for lowpass xover.
Can I really set the inputs to LLMMHH and get full range on 3/4 and 5/6 ?
I hope I've explained this clearly.
As you might tell, I'm a bit of a novice to digital loudspeaker management.
Thanks for all comments.
Dan
I'm going to get into this this week. I've have an RTA & mic, etc. that I get setup. Changing to 2ch - 3way and see if I can get full range on 3/4 and 5/6.
Mike
Dan
