Difference between 9008 and 9008ii
Dan/Rob.
Can you please explain to me what the difference is between the 9008 gen 1 and the 9008ii?
Andrew
Andrew
- Increased DSP speed by 25%
- Added 3-wire mode to control inputs
- Added the ability to use digital I/O cards
Dan
Do those changes you listed apply to the 9008ii or the 9088ii (or perhaps both)?
I am particularly interested to know about the 9008ii vs 9008 gen 1.
Andrew
There are no functional differences between a 9008 and a 9008ii. The only change is a different networking chip which means they use different firmware. Their capabilities are identical.
Mk1 devices:
9088
9000
Mk2 devices:
9088ii
9000ii
9008
3088
Mk3 devices:
9088iis
9000iis
9008ii
Mk1 devices are the 80MHz processors.
Mk2 devices are the 100MHz processors with the other changes listed in my first response.
Mk3 devices use a different network chip.
Yes, the naming is incredibly stupid.
Dan
Cheers
Rob
I'd like a London but quite frankly 9088's are a great buy on the 2nd hand market right now.
I have no idea what the difference in sound quality is like between the 'greens' and the 'London' (if any) but since my use of these boxes is for HT, I doubt I'm ever going to pick it up.....and there's no way I'll be doing any A/B'ing.
Dan, thanks for the explanation showing the differences between the models. You're right, the naming should have been a lot clearer.
Cheers
