BLU-100 Not Found on Network after changing IP address
All,
I received my new BLU-100 and anxiously connected it to my standalone 192.168.1.### network.
I also have the network connected to a DHCP server so I figured it would default to some unknown IP address since it does not have a front indicator to tell me the address.
I changed my primary network to see the BLU-100 and there it was just as anticipated.
I changed it's settings and here is where I think I might have messed up.
I changed it to 192.168.1.255 which may have some other network significance to which I am unaware.
Switching my computer back to the 192... network, I am able to see all of the other devices on the network:
(2) BLU-160
(23) BLU-120
however the BLU-100 is nowhere to be found.
Question 1) Is the IP address that I used a \"no no\"?
Question 2) How can I reset the BLU-100 to it's default settings (DHCP) so that I can see it again.
HELP ME
(2) BLU-160
(23) BLU-120
HELP ME
If you are able to connect to the serial port on the BLU-100 you can use the London Configurator tool (available from 'Help' \\ 'Run Utility...' menu. In there you can adjust IP settings.
Graham
BSS Tech support called back and let me know of the tool located in the Help file of London Architect. I simply entered the MAC address and changed the unit to 192.168.1.254 and it was discovered.
Ken B.
