Emergency mute
The problem I've had with using a \"Gain Timed\" for an \"E-mute\" recovery is that it brings the level to a specific setting and not a relative one. I typicaly like the level to return to where it was before the mute occured and I don't like having too many gains in a signal path. Thus the best way I have found so far is using a tone generator through a gain (whose mute is triggered along with the e-mute, but in the opposite direction) into the side chain of a ducker. Please let me know if I am wrong.
It keeps it perfectly out of user controls. Have it in the signal path at 0dB and make it ramp up after muting back to 0dB. It will not affect your system volume setting before and after emergency mute.
To make things simpler put it at the input to the system side (like right after source select/matrix). That way you only deal with a few of them as opposed to having one on each output.
Dan
If you really want to give the end user admin privileges, just put a big text object next to your fire mute \"don't touch- part of life safety system\".
But, creating a couple of user panels with all the controls they will ever need- even system EQ and limiter settings if you are so brave, is the way to go. Then create a user account with access to those pages but with no design privileges. It doesn't take much time to set it up, but it can save you panic phone calls on a Saturday night.
