BLU-80 Only shows 1 control in operate
I've designed a new program for a BLU-80 and have successfully uploaded to a BLU-80 box. However, I can only see 1 control panel when I go to operate mode. How do I get to see all the other default controls in my program?
Jason
Jason
When you are in Operate Mode, go to the \"View\" menu and select \"Design\". You will see a hierarchical folder/file structure. Expand the \"Control Panels\" folder and you will see a folder for all you Custom Control Panels and Default Control Panels. Simply navigate to the Control Panel you wish to open and then double click it.
Tip: You can also open the Main page or Configration page in Operate Mode. In the Design View, simply navigate to your BLU-80 in the \"Devices\" folder and double click it.
