Scheduled Mute
Can you schedule a mute and then disable it by pulling out a jumper on a control port? Actually, maybe add the jumper to disable the mute. Like a user dongle.
Just use a logic source, drag it onto control port of your choice, then wire the calendar and the logic source through a 2 in 1 out truth table and program your states. Have 1 preset recalled on output of the truth table going high and another on it going low.
That will let you plug in the jumper at any time- before the due date (for example if the bill is paid) or after the mute has gone off and you were called to \"fix\" the system.
PS: You might also want to enable box security so that it is impossible to reprogram the system from scratch for a fraction of the money that might be owed to you.
Dan
Of course, this would also require a telephone card in one of the devices, plus a telephone connection.
