Creating a Bass Lift volume control
This guide will outline a method by which a low frequency boost or cut can
be applied to a signal depending on the level of a Gain Fader. One way of
achieving this is by controlling the relative levels of the outputs of a Crossover
processing object that is dividing the signal into low frequency and high
frequency signals. When running at quiet volumes the low frequencies would
have a higher relative level. As the volume is increased the low frequencies
would increase more slowly in proportion to the high frequency signal. The
resultant effect is a bass ‘lift’ at lower volumes.
More.....
>>>Click here to download the full PDF.<<<
__________________
Technical Support Team
BSS Audio
8760 South Sandy Parkway
Sandy, UT 84070
