PC Control of a 355
I've had a 355 for many years now and recently found a need to start using it again. I want to use it as a simple crossover, and would like to try out current PC control of it.
I remember using the old SoundWeb. I'm seeing conflicting info.
Can I the London Architect to latch on to the 355?
Is it worth the effort since I've already dialed in the points manually?
Any suggestions on where to start would be appreciated.
fcb
fcb
This application can be installed on Win98 or Win XP, however the serial port will only function with Win98.
Since you have already configured your FDS-355 there is no real need to go to the trouble of installing Win98 unless you really think that it is necessary.
It could be useful to install SoundBench on Win XP for the purposes of seeing the configuration of the FDS-355 represented graphically, which might assist you in programming the device, if only to make sure that you have not overlooked any of its parameters.
Thank you for saving me lots of time!
fcb
