Triggering a timed gain with calendar
Trying to trigger a recurring ramp up and ramp down on a \"timed gain\". Can't seem to get a preset to set on the \"timed gain\" either. What am I doing wrong?
Dan
What I'm trying to do is to schedule recurring \"ramp\" up and \"ramp\" down on a timed gain. I can get a gain to jump from level to level but how do I get the timed gain button to go hi to start the ramp at scheduled times?
Much thanks, Carlos
To trigger the fade with logic, you link the Fade button to a Logic End and then cause the Logic End to go high. It's your responsibility to make sure that the Logic End goes low again before the next time you want to trigger a fade.
To trigger the fade with a preset, add the Fade button to your parameter preset group, then right-click on the Fade button and hit Properties. In Properties, look in the Operation section for the Type property and change it to Timed. Look a little further down for the Timeout and set it to 1. Hold down the ALT key and click the Fade button to turn it ON and then save your parameter preset. Hold down the ALT key and turn the Fade button OFF.
Dan
Extra Credit: link the Fade button to a Logic End, set the Fade button type to Timed, make the Logic End go high, and watch what happens. I can think of several really funny applications for this. The simplest (and least evil) is a volume control that does a 5 minute crawl back to it's \"normal\" position no matter what level you set it to.
Thanks for your help.
Dan
