Crossover delay & Threshold problems
I installed a Blu16 with v3.04, firmware updated with no glitches. So, I bring device online to make crossover adjustments and notice the crossover delay has no parameter adjustments and the threshold metering is not present.
Offline I see adjustment windows for crossover delay & threshold metering. Online there are no values for delay & no threshold metering.
I uninstalled v3.04, re-downloaded, reinstalled, and re-opened the file. Same problem.
Has anyone experienced this and what needs to be done?
  • By default the Delay and Meters on the Crossover object are OFF.
    Simply select the Crossover object in the Configuration and then bring up the Properties window. Now set \"Delays On\" to Yes and set \"Meters On\" to Yes.
  • Well that's just too easy. Thank you for the reply.
