BLU-80 replacement CM1
anyone know if the CM1 module is replaceable in the field? I have come across a unit that have a toast primary channel and will need to replace the module.
thanks
  • The CM-1 cards are replaceable in the field. They are fixed to the mainboard with four screws and connected with 80 pins.
    Cut the power to the device, then open the lid. The CM-1 appears as a blue circuit board about 3.5\" square. Remove the four fixing screws and carefully lift the card out from the back. When installing the new card, line up the Ethernet ports and gently push down teh back of the cards onto the connecting pins. Then replace the screws.
    London Architect will probably prompt you to load the firmware into the device when you go online. This ensures that you have the correct firmware running in the card before you go online and load the Configuration.
  • Thank you very much! Been a great help with this issue.
