Connecting cobranet
Just a few quick newbie questions:
When slaving a BLU-32 to a BLU-80, which cobranet jacks should be used on each device--primary or secondary?
In the absence of a crossover ethernet cable, will an ethernet bridge (Linksys WET-200) facilitate a cobranet connection between a blu-80 and blu-32? Are there any additional steps other than plugging both devices into one of the free ports on the ethernet bridge unit?
Thanks!
Thanks!
The WET200 probably won't work, but you can give it a try. It will most likely fall over dead as soon as it gets hit with a CobraNet bundle. Not permanently dead, just sobbing in the corner in a fetal ball until you remove the CobraNet and reset it.
\"Additional steps\" would include programming the devices and assigning the CobraNet bundle(s).
Dan
I don't know how to assign a cobranet bundle. Can you help with this? I would be happy to follow any instructional documents if they're available. Thanks.
We also host them in varying cities around the US.
Level 1 and Level 2 are now globally standardized courses, so you can even find them in different cities around Planet Earth.
Check out our training website to find a live class:
http://www.bssaudio.com/training/live_training
-Kevin
I just spoke to Will at tech support and he very helpfully explained the concept of cobranet and also how to get all my devices recognized on the same network. Thanks for referring me to the training sessions anyway.
