Blu6 controling different volume controls reloaded
This goes more or less out to Dan, and since the application guides section is closed for writing (good idea!) i open this post.
Well, as with the actual fireware soundweb is able to send control messages over IP, the idea is to realize the Blu6 controling different volumes example not with the serial bridge, but with IP-messages sent to the loopback interface (127.0.0.1) or the IP Adress of the soundweb.
Do you think that'll work? Is there any special considderation to be taken into account or is it just change the serial triggers to ip-messages.
I have an application, where i'd like to do this type of control, but since there was this need to bridge (and loose) the serial port, I never did this.
Regards!
Regards!
Dan
