IP to serial adapters
Has anyone tried using an IP to serial adapter with the new ethernet trigger table to send serial commands to a device? I'm basically looking for a way to expand the serial ports on the box. I have a single Blu-800 in the rack and want to control two serial devices. Neither device will accept control over IP directly.
What you need is a serial switch like the 232BSS4 from B&B. That will allow you to route your serial strings from the Soundweb to multiple devices.
If your serial devices aren't all the same baud rate, you'll also need one or more baud rate converters like the 232BRC from B&B.
Dan
I saw an IP to 2 port serial converter, but it would have required drivers to map to the ports as you mentioned.
I have to say that the help files in soundweb are some of the best help files I've seen. I always start there and most of the time find what I need. Since most product has terrible help files, I think we're conditioned to not even look there.
I.e. You can login into this TCP to RS232 device and specify: \"When XX command recieved from IP Network, Transmit XX serial string.
This would make it really easy to control multiple basic RS232 devices like switching multiple Projectors and Tvs on and off in a venue from within LA.
Use half as many logic sources as you need serial commands and using the DI tool look up their on/off control strings.
Then create a Serial Trigger object with as many inputs as logic sources and set it to Type:list . If you need more than 64 commands, just use a second Serial Trigger object and more Logic Sources.
Now you can enter the desired RS232 strings in the list and just turn on and off the logic sources from TCP commands.
It's very simplistic but it should work OK as long as your TCP sending device can be taught to send correct strings to your Blu device.
You can go out of London into it and out to 4 other devices.
Other than that tere is the Aurora Multimedia WACI Nugget Serial.
http://auroramultimedia.com/?section=products&id=108
it will take TCP and translate it to RS232 with your custom table.
Have a look at the Global Cache iTach IP2IR.
The Global Cache stuff is pretty cool all the way around, they make some very handy products.
Forget using the iLearn tool.
open the iTest tool, sent the 'Literal' command of get_IRL
then send the required IR command to the iTach box from your remote... the return window will show both the ASCII and the required HEX codes.
From here you can very easily enter the HEX codes into the Ethernet table in Architect. (When i tried to use ASCII commands in Architect they always appeared to get truncated)
Have tested quite a few codes and all work so far... Hope this helps. Was frustrating me for a while.
\"then send the required IR command to the iTach box from your remote... the return window will show both the ASCII and the required HEX codes.\"
I sent the literal get_IRL and see the ascii and hex codes for this command, but how do I send the IR command to the iTach box from the remote - do I point it into the ir receiver on the iTach unit (as we're told to do with the iLearn instructions) or somewhere else.
Also, when I used the iLearn app and received the codes by pointing the remote at the iTach, and then tested the obtained codes, they all work. However, when I convert them to hex within ilearn, then copy them into the Ethernet trigger device within London, I don't get any response at all out of the ir emitter connected to the iTach.
I noticed that the hex code in the trigger table is also incomplete and it appears that the slot in the trigger table can only accept a certain number of hex numbers, after which it just drops the remaining ones. Have you experienced this? Do you have a work around? Or am I missing something?
But when you put the code in the Ethernet Trigger table, the code is too long.
Using the GC code it will fit, but it doesn't work. When i recieve the command thru the app \"Sockettest.exe\" it's the right code. I've tried to send the recieved code with \"Sockettest\" to the iTach and then it works.
A friend told me to put Carrier return and Line feed behind the GC code. Thried that without succes.
Is there somebody who knows how to fix this?
Is the Connected indicator On when you send the string?
If you want to add CR or EL, set the Ethernet Trigger's edit page to Hex. Then enter 0D for Carriage Return and 0A for Line feed.
FYI, the Ethernet Trigger can accept messages of up to 77 bytes in length.
The connected indicator is on.
If i do what you sugest, set the edit page to HEX, the command is too large to fit. So it's also not possible to put something behind the command.
This is the ASCII command: sendir,1:1,1,38000,1,1,341,171,21,22BBBBBBB22,64CCCCCCCBBCCCBCBCCBBBCBC21,1514,342,85,21,3800
When i put in HEX it's like this:
73,65,6E,64,69,72,2C,31,3A,31,2C,31,2C,33,38,30,30,30,2C,31,2C,31,2C,33,34,31,2C,31,37,31,2C,32,31,2C,32,32,42,42,42,42,42,42,42,32,32,2C,36,34,43,43,43,43,43,43,43,42,42,43,43,43,42,43,42,43,43,42,42,42,43,42,43,32,31,2C,31,35,31,34,2C,33,34,32,2C,38,35,2C,3
And i think that the HEX command is not complete.
Out of interest, what does this command do?
But when i try to control an Optoma projector the lenght is also this kind of lenght.
Lets fast forward a bit now to Audio Architect - I've been brave (silly) enough to down load the beta version and of course, inspired by the above problems, tried to see what I could achieve with Audio Architect and the Global Cache IP2IR interface.
It turns out the AA accommodates longer strings (bonus!) Unfortunately, I still can't get AA to talk to the IP2IR device, even though when \"online\" the status of the ethernet trigger table I'm using to load the IR strings into shows that the device is connected. I assume then that my IP address and port address are correct. If I unplug the ethernet cable of the IP2IR I see the Ethernet trigger \"connect\" light go out - so the comms channel is definitely correct.
I then went on to use a packet sniffer (Wireshark) and I see the logic presses within AA (when on line) sending out commands to the BSS unit, and then I see a reply from the Blu stating that the \"Ethernet Frame Check Sequence is incorrect\". I have no idea what this means or how I get around this.
If anyone has ideas or suggestions, I'd love to hear from you.
I tried a similar thing but was sending a carriage return after every string which didn't work of course.
One thing I've been trying since you solved this problem is how to \"release\" a logic source button which is acting as a volume button so that I don't need to press it twice to keep triggering a volume up or down command.
The perculiar thing is, I can get it to work in operate mode perfectly, but it doesn't when online :? .
Anyway, thanks again for your solution
Con
