Custom Control Panels issue
All of a Sudden.
When in DESIGN MODE
Whenever I click on buttons I have created to link to other custom pages, it? gos to that page. I'm in Design Mode and alt is not stuck.
This has just started happening. ANy ideas .. Very Frustrating as I cant even delete the button as when I click on it, it gos straight to the linked page
ANy ideas? .. I've tried re-installing LA, but the problem is still around. I've tryed creating a whole new file, but its doing the same thing.
    That's not happening all of a sudden, it's the default behavior. If you want to disable that behavior, click on the VIEW menu and you'll see that the option at the bottom of the menu (Auto Page Change) is active. Click on Auto Page Change to disable it and hyperlinks will only work in operate mode.
    Editing is much faster if you leave that function enabled. If you want to select a hyperlink button for editing or to delete it, just click-drag to draw a bounding box around the button and it will be selected. Alternately, right-click the button and it will be selected without being activated.
    Dan
  • Thanks Dan
