drop out / Fall over
We have a newly christened BSS system. The system 3 DSP's and a fleet of BIB BOBS connected by SM Fiber. We are experiencing a drop out as if the system is trying to cut over to the other side of the ring. Ironically this does not occur on all signals. If the signal is coming from a DSP controlled venue, it is usually solid. If it's coming from a BiB though the DSP back to its own BOB we hear it. In one venue the BIBs seem to work OK, the next one on the loop in either direction exhibits the issue.
Has anyone seen anything like this? We are getting ready to bypass each venues fiber to see if any one site is causing the issue.
On another note, changing the mastering in the DSP's changes the nature of the problem. When all were set at 128 even the DSP venue sourced items dropped out. Making one the master solved that at least. (no cobra net)
Hmmmmm.
Hmmmmm.
