HiQ net iOS control
It's great that there is a native iPhone and iPad control app. I can't wait to try it.
But can any of the Harman people explain what exactly is not possible in the app?
Reading the only review on iTunes it seems that the app is fairly limited:
Get used to reading the words \"HiQnet Motion Control does not support this type of control\" when working in System Architect. I didn't expect to find it would support the intricate designs I usually create in London Architect but it can't even support half of the basic controls in System Architect.
It's functional, I won't take that away from it. That said, functional is not nearly enough to keep my customers happy.
AEC
AEC Enable
AGC Enable
Mic Active
NC Enable
NLP Enable
Signal Threshold
AEC Input Card
AEC Enable
AEC Mute
AGC Enable
Dry Mute
Mic Active
NC Enable
NLP Enable
Phantom
Reference
Signal Threshold
Analogue Input Card
Mute
Phantom
Reference
Analogue Output Card
Mute
Reference
ANC Gap
Gain
Gap LED
Max
Min
ANC Non-Gap
Gain
Max
Min
Automixer Gain-Sharing
Auto
Aux Gain
Aux Mute
Channel Aux Gain
Channel Gain
Channel Group Gain
Channel Mute
Group Mute
Group Route
Off Gain
On
Output Gain Left
Output Gain Right
Output Mute Left
Output Mute Right
Override
Pre/Post
Solo
Automixer Gated
Auto
Cascade Link Healthy
Channel Gain
Channel Mute
Default Mic
Gain Left
Gain Right
Gate Open
Hysteresis
Last Mic Hold
Local
Low Priority Duck Gain
NOM Attenuation
Off Gain
On
Output Mute Left
Output Mute Right
Override
Sensitivity
Solo
Threshold
BLU Device
All the CobraNet indicators
Most of the BLU link indicators
CM-1 Mute status
BLU link Rx
Reference
BLU link Tx
Reference
Compressor
Auto Release
Gain
Crossover
Gain
Mute
Digital Input Card
Bypass
Mute
Reference
Digital Output Card
Bypass SRC
Mute
Reference
Ducker
Range
Gain
Bump Down
Bump Up
Gain
Mute
Gate
Range
Graphic EQ
Band Level
Flat
Hybrid Input Card
Channel Mute
Dial Tone
DTMF Detect
Phantom
Phone keys (0,1,2 etc)
Recall
Reference
RX Mute
Store
TX Meter
TX Mute
Input Bundle
Channel Meter
Dropouts reset
Meters Enabled
Leveller
Active LED
Max Gain
Target Output
Limiter
Threshold
Matrix Mixer
Crosspoint Gain
Crosspoint select
Meter
Reference
Meter Trigger
Reference
Mixer
Aux Mute
Channel Aux Gain
Channel Gain
Channel Group Gain
Channel Mute
Group Mute
Group Route
Output Gain Left
Output Gain Right
Output Mute Left
Output Mute Right
Pre/Post
Solo
Aux Gain
N-Input Gain
Channel Gain
Channel Mute
Main Mute
Master Level
Output Bundle
Channel Meter
Dropouts reset
Meters Active
PEQ
Bypass All
RMS Meter
Reference
Room Combine
BGM Gain
BGM Mute
BGM Source
In Active Group
Master Gain
Master Mute
Source Gain
Source Mute
Source Matrix
Input
Source Selector
Input
Timed Gain
Cancel Fade
Fade
Gain
Mute
Timer Gain
That is indeed a fairly limited set of controls.
On my control panels I rely on Logic Sources, Gains and source selectors a lot. Sometimes I give the users some basic EQ and controls for live microphone input.
With the currently available set I could not set the mic input sensitivity, turn on high pass filter (without some routing gymnastics) and adjust mic dynamics processing.
I hope this is all still work in progress and you will be adding more controls to the list.
In the meantime, there are some workarounds for getting into the Logic domain such as using e.g. Mute buttons from N-Input Gains to drive the Logic Sources, and placing the Mutes on the iOS panels. There are creative workarounds for other parameters too. 8)
I'll be keeping my eyes on the Soundweb London User Group to monitor the iOS-related posts - it'll help us make sure we're prioritizing the new controls and parameters correctly.
After all that, I set the inputs on the source selector back to 9. I exported that and imported to System Architect as a drop down box. It seemed to work
A little tedious, but it's not too bad if you have only a couple gains to work with. Unfortunatly, since much of the other rotary type SVs (ration on a compressor for instance) aren't in the list, I haven't found a way to make those work yet.
Or has this been put on the Backburner due to the upcoming Audio Architect release? From all the info on the Harmon website is appears obvious that Audio Archetect might see the end of LA?
I promise I'll post the list here as soon as I can.
:shock: Watch this space...
Thanks for the update Ian
Gain
Polarity
Timed Gain
Polarity
Mixer
Polarity
Automixer
Polarity
Gated Automixer
Polarity
Gate
Threshold
Manual Open
Open
Limiter
Polarity
Ducker
Threshold
Leveler
Threshold
Expander
Threshold
ANC
Ambient Threshold
Gap Threshold
Non-Gap ANC
Ambient Threshold
Crossover
Limiter Threshold
Polarity
Noise Generator
Level
Tone Generator
Level
Meter Trigger
Trigger
Room Combine
Partition
Analog Input Card
Gain
Digital Input Card
Error
Non-audio
AEC Input Card
Noise Cancelation Level
AGC Max Gain
AGC Min Gain
AGC Max Target
AGC Min Target
AGC Current Gain
AGC Attack
AGC Release
Hybrid Input Card
Gain
TX Gain
RX Gain
DTMF Level
Ring Level
Side Tone Gain
Analog TX Gain
Analog RX Gain
Off Hook
Limiter Active
Current Overload
CobraNet Input Bundle
Audio Received
Logic Source
Input
Logic End
Output (only when object has one input)
