BLU-160 Phantom Power Noise
Hello All,
I currently have a system that has (2) BLU-160's all with analog input cards and (2) BOB's. Every time I enable Phantom power on either BLU-160, I get high pitched noise. I am trying to figure out the issue and during my testing I used an external Phantom power supply for some of the microphones (Note: The external phantom power supply was powered from a different circuit). When I used the external phantom power supply the noise was gone. Any ideas on what it could be? I am thinking it's a ground loop issue of some sort, but since it's microphones on the other end and not another piece of gear it makes it much more difficult to track down.
David
  • I had a similar problem with an Analog In card on my Blu-160. In my case, it was a bad pre-amp on that card. It was clean with no phantom power, but the minute I turned on phantom power I got this high pitched whine. The input had been connected to a 1/4\" patch bay and as the patch cord was inserted/removed it shorted the input and caused the pre-amp to blow. I sent it back and had it repaired which fixed the issue.
    -david
