FDS-355 Set-up
I am looking wondering if someone can write me a step by step guide on how to set up a bss fds-355 using the on-board controls. I want input A to feed output 1 with a low end signal and output 2 with a high end signal.
The I want input B to feed output 3 with a low end signal and output 4 with a high end signal.
On both of these the crossover point wants to be around 120HZ.
Thankyou to anyone who can help.
http://www.bssaudio.com/downloads_archived.php
If you would like a more graphical representation of the signal routing then install Sound Bench available here...
http://www.bssaudio.com/software.php?software=Soundbench&Submit=Go
You can install it on XP or Win7, but you will need Win98 if you wish to make it work with the FDS-355. I would just use it to get a feel for the routing and parameters. Then you can easily program your FDS-355 from the front panel.
could you give me one,please.
