Need help with London/Crestron integration
I'm very new to SIMPL programming. Hopefully someone can guide me a bit.
I want to use the smallest Crestron room controller to translate between Blu-160 and another manufacturer's piece of equipment that has a published Crestron module.
In London's Custom Panel I need to display the other piece's status (on/off/fault) and turn on a few buttons.
Is it possible to just pass the signal from let's say the 8-channel gain block's mute buttons directly to the other module's buttons? Or do I have to go through some sort of logic processor in Crestron's own library? If yes, which one would I use?
I will not have a Crestron touch panel in the setup to trigger or display anything. It all has to happen directly in the controller.
Hopefully all this makes sense.
If the \"other\" modules inputs are digital (i.e. blue line), then most likely, yes, you can tie them acrossn directly. If not, you need to know what type it is before you know what SIMPL objects to use to interface.
