Level drop at the n-input parametric EQ Output
Hi,
I use an N-Input parametric EQ with 2 channel, and the channel 1 has a drop of aprox 3dB at the output (channel 2 is fine...). Am I missing something? As a test I feed both input with the same tone generator and I put meters on all in/out.
Try deleting the object and replacing it.
This might be one of those one in a billion glitches. You should win some sort of prize if that's the case :-)
