blu100 sending IR via iTach IP2IR
I'm trying to change channels on digital set top box decoders using infra red by way of an IP to IR interface (Global Cache iTach IP2IR). My control interface is an iPad running motion control.
I've been able to learn the codes using the iLearn application that is available through Global Cache. When i test the codes learned, by \"sending\" them (using iLearn), the devices respond as expected. The iLearn app has a \"hex\" conversion feature that I use to convert the strings. I then copy and paste these into the London Ethernet trigger device that has multiple logic source buttons for triggering.
I have set up the correct IP within the properties of the Ethernet trigger device (that correspond with the iTach IP2IR - 192.168.1.70, and port 4998).
What I have noticed is that when I copy the hex values of each command from the iLearn app into the Ethenet trigger device, the commands are truncated - as if there is only a limited space, with everything exceeding that just being left off.
Of course when I load the file and beging to test the Blu with this \"truncated\" information, nothing happens, and I know for certain that nothing is getting to the IR flasher connected to the correct port on the IP2IR as I don't see it flashing at all.
I've searched through all of \"third party control\" in the forum but nothing remotely similar exists. Does anyone have any information they can share with me that sheds some light on how to get this working?
However, I've been experimenting with Audio Architect, and it can take a lot more - exactly how many, I don't know, but the same strings that were truncated in London Architect, can now fit into the list/table of the Ethernet or Serial trigger*
*fine print.....
As yet I still have not been able to make this damn thing work even though I can fit the whole string into the table positions, so I'm still reaching out for help/advice/panadol
I've put the project back up the top of the priority list!
Con
What did it take to get this working?
I would also like to hear how this is done
