Graph Eq link
Hi everybody,
Is there any solution to link two graph Eqs like in the old soundweb designer, to be able to choose between two mono equalization, or stereo equalization without changing the design?
Thanx
  • The large blue rectangular object that contains all the Graphic Eq's faders is not able to be part of a Link.
    You must create seperate Links for each Frequency band.
  • Simo'sSimo's Posts: 16
    That's what i wanted to do (like in my old soundweb designer stuff), but i'm not able to select only one band in design mode... where can i do it?
    Thanx
  • All parameters, links, presets are listed in the Design window.
    Open the Design window and go to Devices / BLU-??? / <name> / Default Config. You should see all the EQ's parameters. Simply drag them onto a Custom Control Panel.
    Sorry, i'm not sure to understand well...
    I can do it with two parametric Eqs, but not with the faders (for example 25Hz band fader) of two graphic Eqs, because i'm not able to select only one band...
    On graph Eq i can link the \"flat\" button or the the \"selectivity\" control,... but band faders aren't selectable separetly.
    If i drop a graph Eq from design window to a control panel, it will do the same has a copy/paste of the object (what i've allready did), but i won't be able to separate the band controls to link them.
    edit: I wasn't looking at the right place :) ... i'm trying...
    Did i miss something?
    Thanx for your great help :)
    It works :D
    Thanx so much !!!!!!!
